SatcomGlobal
Dec 01, 2017Aspirant
Prosafe FVS318GV2
Hoping someone can assist with an issue I am having with a Prosave VPN firewall. For LAN TO WAN traffic I have some rules that allow traffic to specific destinations to a specific port. The Default O...
SatcomGlobal
Dec 11, 2017Aspirant
Hi DanaA
For the Netflow I used Solarwinds.
I have also changed the default outbound policy and when checking the logs i can see the traffic going through.
The firmware version on the firewall is currently 4.3.1-9. Could this be the reason for the traffic passing?
SatcomGlobal
- DaneADec 11, 2017NETGEAR Employee Retired
Thanks for the feedback. Firmware v4.3.1-9 is the initial released firmware for the FVS318Gv2 and it might be possible that its the reason why the problem occurs. For us to isolate the problem, I suggest you to upgrade the firmware to the latest version in a ladderized manner. The procedure will be: first, upgrade the firmware from v4.3.1-9 to v4.3.1-11. Then, upgrade the firmware from v4.3.1-11 to v4.3.2-7 and so on until you reached the latest firmware v4.3.5-3.
Be reminded to perform a factory reset after upgrading the firmware to the latest v4.3.5-3 then reconfigure the settings from scratch in order to start clean using the latest firmware version. Then, observe if the problem will still occur.
DaneA
NETGEAR Community Team
- DaneADec 14, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to upgrade the FVS318Gv2 to the latest v4.3.5-3 then perform a factory reset and reconfigured the settings from scratch? If yes, let us know the result.
DaneA
