jmcdpugall
Jan 29, 2020Tutor
BR500 and Panasoniv Voip
Hi, I wonder if anyone out there has seen similiar issues. I have 2 VPN 500 routers with an Insight VPN tunnel between them. One side has the IP address of 10.0.0.254 and the other is 10.0....
jmcdpugall
Jan 30, 2020Tutor
Hi Dane,
Thanks for the response.
The Networks subnets have a subnet mask of 255.255.255.0 should be identifed as seperate subnets. All other traffic passes between sites with out issue. I can access resources on both sides of the VPN tunnel without issue. The only problem I have is that the PABX is seeing the source IP of the phone as the local router IP.
c3po
Feb 05, 2020NETGEAR Expert
Could you please try to disable SIP ALG to see if it makes difference? Thanks.
Web GUI -> ADVANCED -> Firewall -> Basic Setup -> Check "Disable SIP ALG" on bottom -> Apply
