ComputerMikes
Dec 26, 2018Guide
BR500 Issues and Feedback.
Been looking forward to the BR500 release for some time now and finally just procured one through Powershift Eval.
First impressions:
DHCP Servers and VLAN setup through Insight got my blood ...
ComputerMikes
Dec 31, 2018Guide
Might take a bit for me to get around to, but usually that has to do with allowing VLAN interweaving which you can turn on and off between the VLANs. A lot of that also depends on the switches you use, if any.
Right now, I'm only using one LAN port with a bunch of cascaded switches and none of my VLAN traffic is able to see any other VLAN traffic. I have it set that way so that on my one VLAN, that's where all my client machines that have infections get connection to the internet and I can't afford to have them infect the rest of my network. Also, I'm running a bunch of GS110TP switches that support VLAN tagging and routing, so even at the switch level, I am covered.
LegitUser
Dec 31, 2018Aspirant
Thanks Mike. A quick ping test would do at this point.
Anyway I started a new thread about this.
https://community.netgear.com/t5/Hardware-VPN-Firewalls-and/BR500-Inter-VLAN-rules/m-p/1683559
