mhndsh
Dec 19, 2018Aspirant
DHCP problem SRX5308 – ProSAFE Quad WAN Gigabit SSL VPN Firewall
Hi, I have less than 100 users with 200 available ips in the dhcp pool.. Latest firmware 4.3.5-3 New clients cannot obtain an ip... I read the similar topics.. i reset it and reconfigure... But sa...
Nodism1125
Jan 01, 2019NETGEAR Expert
Have you tried manually configuring the router setting instead of using the same router config? After upgrading the firmware to version 4.3.5-3.
mhndsh
Jan 07, 2019Aspirant
Thanks for reply..
as i mentioned, yes i did ( i reset it and reconfigure, but same)
i didn't (using the same router config)
