lumandryk
Jul 28, 2017Aspirant
Firmware FVS318N_v4.3.5-3.img invalid or corrupted
Trying to update my router to this firmware (FVS318N_v4.3.5-3.img) and both the web gui and the telnet interface keep complaining that the file is invalid or corrupted. Does anyone know how to solve ...
DaneA
Aug 01, 2017NETGEAR Employee Retired
Thanks for the feedback. I suggest you to try to clear the cache of the browser(s) you are using as well as try using other browsers like Firefox in upgrading the firmware via the web-GUI of the FVS318N.
DaneA
NETGEAR Community Team
lumandryk
Aug 01, 2017Aspirant
Just tried upgrading the firmware via web-gui in firefox (freshly installed) and as expected it didn't work, said that the firmware was invalid or corrupted. FWIW I also tried installing previous versions, from the very same files that worked in the past, all failed in the same way. I also tried the telnet route, unsuccessfully as well.
Any other suggestions? Is there a way to force installation and bypass all validation?
Thanks!
