RobSCyS
Jan 09, 2017Aspirant
FVS318G outbound filter doesn't work.
I'm trying to block outbound traffic for certain users based on a schedule. My time is set correctly. In the outbound rule my default is to Allow all. I create a filter for 'Alllow only during ...
ChenX
Jan 09, 2017NETGEAR Expert
Hi RobSCyS
Welcome to the community! ![]()
Kindly answer the questions below:
1.What is your FVS318G firmware version?
2.Can you show me your firewall and schedule config?
I have tried on my FVS318G on V3.1.1-18,but did not find your problem.
My Pc ip is 192.168.1.22,today is tuesday,I can not access the internet.
Regards
RobSCyS
fvs318gV2 is using latest 4.3.4-2
The device i want to block has been assigned to group3 in the lan configurations/lan setup/lan groups
- RobSCySJan 09, 2017Aspirant
And thanks for the help!
I'm pinging a public server on the internet from the group3 computer as my test of 'conectivity' to the WAN.
- ChenXJan 09, 2017NETGEAR Expert
Hi RobSCyS
1.Which time zone is yours?
It seems to be a issue with west time zone,if you want the filter work,you can set the time zone to Greenwitch Mean Time,then you can block the pc in the shedule,like this:
Regards
- RobSCySJan 10, 2017Aspirant
ChenX
This fits my observations and from my initial testing appears to make schedules work correctly. To better state the problem would you say "Only GMT timezone" works correctly? In other words EST also probably doesnt work correctly?
I didnt see this open bug on the latest release and what steps need to be taken to make Netgear aware of issue?
Thanks for the workaround all be it a little painful given the mental gymnastics to convert time zones when creating a schedule.
Regards
