Digithead
Feb 17, 2017Aspirant
FVS318N Mobile VPN How To?
I've been trying to figure this out for some time now as the documentation for this device is NOT real clear about it at all. I'd like to configure the firewall such that I can get a VPN connecti...
- Feb 19, 2017
Hi Digithead,
Welcome to the community!
If you want to use VPN connect to LAN from your laptop,you can use prosafe vpn client.
Firstly,create a client-to-gateway vpn on FVS318N,then use prosafe vpn client connect to the VPN.
Please see below reference:
http://www.downloads.netgear.com/files/GDC/FVS318N/QSGVPN_4Apr2012.pdfThanks,
Dan
Dan_Z
Feb 19, 2017NETGEAR Expert
Hi Digithead,
Thanks,
Dan
Digithead
Feb 23, 2017Aspirant
Hello Dan,
Thank you for your reply and please forgive my tardiness in getting back to you.
I actually have that PDF already and have tried multiple times to get the Client-to-FVS318N VPN to work but I must be missing something somewhere. It simply would not work. As I mentioned in my initial post, I did purchase a full licensed version of the VPN client so that's not an issue. What seems to be happening is that the firewall's Wizzard never creates the Phase I and Phase II components of the policy so of course no "hand-shaking" ever gets completed resulting in no VPN connection. I just verified yesterday morning that both of my FVS318N firewalls are completely up to date with the latest firmware available so that shouldn't be the problem either.
I'll give this yet another go over the weekend though and see what happens. I'd really like to get this figured out and functioing though as I have two trips coming up soon and I don't like the idea of "poking holes" through the firewalls to get into the network remotely.
- Dan_ZFeb 23, 2017NETGEAR Expert
How do you configed firewall's wan port? The firewall connect to internet directly,or connect to other device?
Thanks,
Dan
- DigitheadFeb 26, 2017Aspirant
Yes of course the firewall is connected directly to the outside world, static IP address and all.
Actually about to just give up on this and find another solution as I've seen several other threads thus far with pretty much the same problem but no resolution.
I at least got to the point where the Client at least tries to connect but then fails with:
SEMD phase 1 Aggressive Mode [SA][KEY_EXCH][NONCE][ID][VID][VID][VID][VID][VID]
Repeats that three times and then quits. Everything on EACH end set exaclt the same. "Authentication (IKE) 28800" and "Encryption (IPSec) 3600" exactly as the PDF recommends... DH-1 set at both ends... but still nothing.
- DaneAFeb 27, 2017NETGEAR Employee Retired
I think it would be best that you post the settings you have configured step-by-step on your laptop and on the FVS318N. In this way, the community members might be able to help figure out what needs to be corrected.
DaneA
NETGEAR Community Team
