Webbwulf
Feb 22, 2020Tutor
Mr1100 mobile broadband disconnected
My mr1100 using simnetwireless says mobile broadband disconnected. Apparently netgear and tmobile are working on a fix and anyone confirm this? Any fixes that I'm unaware of would help. I'm in a rural area and this is my only way of connect besides sprint phone and connections are slow and not consistent any reply would be appreciated.
As we found out that if you are using a data plan for tablet from T-Mobile, the SIM would not work any more with M1. You need to ask T-Mobile to change your plan for Mobile Hotspot for your SIM to work again on M1.
Thanks
- Blanca_ONETGEAR Employee Retired
Hi Webbwulf
Kindly try the following APN settings if this works for you:
APN Name : Fix
APN : b2b.static
PDP and PDP Roaming : IPv4
@melwiththecell shared this information and this resolved the issue:
Blanca
Community Team- Blanca_ONETGEAR Employee Retired
Hi Webbwulf,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team- mikedrAspirant
I just tried that with one of my M1's and it did not work. It just said connected on status then disconnected. I have 2 of these devices and 2 lines that i am paying for and they are currently useless. Also i was not able to downgrade bios, so both are now upgraded to the latest version.
