WMC
Feb 13, 2016Follower
FVS318N requires periodic reboot
I reviwed the community article titled FVS318N router keeps dropping network connectivity, which was closed due to inactivity. I'm having the same problem where the router runs for about a week or s...
DaneA
Jun 14, 2016NETGEAR Employee Retired
Hi noibla,
I am sorry to know about that. :( If only its possible for you to open an online case with NETGEAR Support in order to forward the logs to the engineering team.
DaneA
NETGEAR Community Team
rlcarper
Oct 02, 2016Tutor
I'm very disappointed in the support from Netgear. I have stripped down the router configuration so that minimal logging is enabled and still the loggin seems to be garbled and overrunning. With the Latest software release form august 2016 nothing has changed.
I was never able to create a case with techniocal support due to the impossible menus to input the serial number of the unit which I really have, but seems to be linked to another account (???)
I have trusteed Netgear for many many years (20+) as a reliable networking and firewall product company and the products suited the existing needs, but the Internet connection moved on and now the products seem to be capable of providing the performance, thy don't after 1 day or even sooner.
I reboot the router once in a while and then I'm able to get the speed that I have with my ISP (190 Mbps down and 30 Mbps up). but after a while this drops back to 56/30.
Very disappointed with a product that has a datasheet that claims 250 Mbps throughput. That is unacceptable for business grade products such as the FVS318N
Get this fixed!
- DaneAOct 03, 2016NETGEAR Employee Retired
It seems that you have opened online case # 27489789. I believe that the NETGEAR Support expert assigned on your case has already responded to you and is asking for the serial number of your FVS318N as well for it to be registered. Kindly reply into it and keep us posted.
DaneA
- rlcarperNov 23, 2016Tutor
Hi All,
The support case had led to the unit being replaced but something else happened too. 2 new firmware releases took place. 4.3.4.1 and 4.3.4.2. The 4.3.4.1 release note have the following comments:
Bug Fixes:
- Fixed the issue where the logs are not displayed properly in the GUI and on Syslog server.
- Fixed the issue where the firewall logs contain incomplete logs messages.
The unit was replaced under RMA afer good response from the Netgear team. I returned my old unit and the new unit came in a box where the specs still referred to the old datasheet (95 Mbps WAN-LAN).
Both units (witn 4.3.4.1 software ran fine with the 190 Mbps consistent download. I also further looked into differences in the hardware platform used (Cavium CNS3411 Network processor). Both units were the same.
To summarise: it was likely a memory leak issue in the prior firmware in relation to the log messages prior to firmware 4.3.4.1
- DaneANov 24, 2016NETGEAR Employee Retired
Hi rlcarper,
Thanks for the update.
I'm glad that both units you have are now running fine. It seems that the new firmware has solved the problem. Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
- Retired_MemberNov 26, 2016
I guess we celebrated too soon. Performance dropped back to 50/30 Down/Up.
Case needs to be reopened
- DaneANov 28, 2016NETGEAR Employee Retired
Hi noibla,
Since there is a problem with the replacement unit, you may go ahead and contact again NETGEAR Support. Let them know about the previous case number or the RMA number given to you as reference.
DaneA
- rlcarperFeb 14, 2017Tutor
We're back to sqare one. However, Netgear support is still trying to find options to address the problem.
Currently the daily reboot results in a temporarily speed to 190/30, but within 7 hours, the performance is below 50 Mbps down again
