WMC
Feb 13, 2016Follower
FVS318N requires periodic reboot
I reviwed the community article titled FVS318N router keeps dropping network connectivity, which was closed due to inactivity. I'm having the same problem where the router runs for about a week or s...
DaneA
Nov 28, 2016NETGEAR Employee Retired
Hi noibla,
Since there is a problem with the replacement unit, you may go ahead and contact again NETGEAR Support. Let them know about the previous case number or the RMA number given to you as reference.
DaneA
NETGEAR Community Team
rlcarper
Feb 14, 2017Tutor
We're back to sqare one. However, Netgear support is still trying to find options to address the problem.
Currently the daily reboot results in a temporarily speed to 190/30, but within 7 hours, the performance is below 50 Mbps down again
