WMC
Feb 13, 2016Follower
FVS318N requires periodic reboot
I reviwed the community article titled FVS318N router keeps dropping network connectivity, which was closed due to inactivity. I'm having the same problem where the router runs for about a week or s...
SamirD
Feb 15, 2017Prodigy
I left it in bone stock setup besides changing the subnet of the lan to keep it from conflicting with an existing lan. I ran the dslreports speed tests as they consistantly would max out our connection properly.
I tested a few times after setup.
Then because this was a local lab setup, I ran an iperf to a system on the 'wan' for 24hrs reporting once every minute (iperf -c 192.168.1.11 -t86400 -i60). Once it passed that test, I again ran a speedtest and then called it good.
The next test was putting it into production where the Internet is a 60/5 connection. Normally it would be right at the 60 mark. It tested 65/5.
I would try testing with all the wifi disabled. The wifi on the 318N is terrible. I'm about to get a 802.11ac AP as 802.11ac is faster than the N anyways.
As far as the port forwards, I didn't try any.
Hope this helps.
rlcarper
Feb 15, 2017Tutor
I have an additional Unifi AC-Lite connected. I could try disabling the wifi on the 318N completely, but then what use is the product if it can only go fast with most features disabled.
- SamirDFeb 16, 2017Prodigy
I'd try disabling the internal wifi and see if that fixes it.
As far as what's the good if it doesn't work 100%? It's 10x cheaper than a product that does. And all the routers in this price range are semi-broken like this. But you can usually make a solution using one for 1/4 the cost of an enterprise-class system which would work just as it says (but there's always still some caveats).
To give you an idea of how much more cost-wise, a watchguard t50--which can do about the same as the FVS318N and still doesn't have wifi--costs around $800 on the cheap end.
- rlcarperFeb 19, 2017Tutor
I've been experimenting with disabling the Wifi, but it seems to make no difference.
BTW, when I reenable the wifi, the radio chooses a suboptimal channel when configured for Auto and when I try to configure a fixed channel (channel 11) the UI doesn't sseem to honour my request by sticking to any other channel except the one I desired:
Region: Europe Country: Netherlands Operating Frequency: 2.4GHz Mode: ng Channel Spacing: 20/40 MHz Current Channel: 1 - 2.412GHz Channel: 11 - 2.462GHz Default Transmit Power: Auto (dBm) Transmit Power: 16 dBm Transmission rate: Best - rlcarperFeb 19, 2017Tutor
Some of the messages in the log file. Reappearing the Should Overwrite TID here for NULL data....
Sun Feb 19 21:59:26 2017(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data
Sun Feb 19 21:59:26 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] iReq.i_val : 16
Sun Feb 19 21:59:26 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] iReq.i_val : 2412
Sun Feb 19 21:59:26 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] pIfName : vap0
Sun Feb 19 21:59:22 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] iReq.i_val : 16
Sun Feb 19 21:59:22 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] iReq.i_val : 2412
Sun Feb 19 21:59:22 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] pIfName : vap0
Sun Feb 19 21:59:21 2017(GMT+0100) [FVS318N_Rogier][Kernel][KERNEL] Should overwrite TID here for NULL data
Sun Feb 19 21:59:18 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] iReq.i_val : 16
Sun Feb 19 21:59:18 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] iReq.i_val : 2412
Sun Feb 19 21:59:18 2017(GMT+0100) [FVS318N_Rogier][Local0-wireless][UDOT11] pIfName : vap0
