woodd
Aug 31, 2015Aspirant
FVS336G How do I change the certificate presented from 192.168.1.1 (Default admin)
I have the FVS336G installed to load balance between two internet providers (small office) The admin page is SSL secured with a self signed NetGear CA certificate - After I add this certificate into...
- Sep 03, 2015
Hi woodd,
The FVS336Gv1 does not have a console port whereas both the FVS336Gv2 and FVS336Gv3 does have a console port. However, there is still no option to update the admin certificate nor swap out the certificate file via a console connection.
As per the CLI reference manual, it says on page 6: "You cannot generate and upload a certificate through the CLI..." You may access the CLI reference manual here.
DaneA
Netgear Community Team
DaneA
Sep 02, 2015NETGEAR Employee Retired
Hi woodd,
I have checked that you have already contacted Netgear Chat Support and you have an FVS336Gv1 which is already End-Of-Life (both FVS336Gv2 and FVS336Gv3 are not yet EOL).
I don't think there is way to update the admin certificate nor swap out the certificate file via SSH.
Welcome to the community! :smileyhappy:
DaneA
woodd
Sep 02, 2015Aspirant
Well then -
- let me ask the same question about the FVS336GV3 (or V2).
Can you change the certificate used for the Admin page on the FVS336GV3?
I would like to know that I will not be forced into some perpetual hardware upgrades due to the loss of being able to connect with a browser.
Better yet, if access could optionally be in the clear for LAN connections.
...Dale
