woodd
Aug 31, 2015Aspirant
FVS336G How do I change the certificate presented from 192.168.1.1 (Default admin)
I have the FVS336G installed to load balance between two internet providers (small office) The admin page is SSL secured with a self signed NetGear CA certificate - After I add this certificate into...
- Sep 03, 2015
Hi woodd,
The FVS336Gv1 does not have a console port whereas both the FVS336Gv2 and FVS336Gv3 does have a console port. However, there is still no option to update the admin certificate nor swap out the certificate file via a console connection.
As per the CLI reference manual, it says on page 6: "You cannot generate and upload a certificate through the CLI..." You may access the CLI reference manual here.
DaneA
Netgear Community Team
DaneA
Sep 03, 2015NETGEAR Employee Retired
Hi woodd,
DaneA
scsailor
Oct 28, 2015Initiate
Hi,
I too have run into the problem that trying to connect results in this message:
"An error occurred during a connection to 192.168.2.1. SSL received a weak ephemeral Diffie-Hellman key in Server Key Exchange handshake message. (Error code: ssl_error_weak_server_ephemeral_dh_key) .
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
Please contact the website owners to inform them of this problem."
I do not know how to update the firmware if that is what it takes, nor update the certificate.
Will this be something I can fix? Or will I need to replace the Firewall? Your response to the original question seems to be that "It cannot be fixed on the Netgear FVS336G Firewall"?
Please help provide a solution as this is my router to my work and I use it all day, every day. No network, no job.
(I only have one old laptop that can still connect, Every other device I have gets the same complaint when trying to connect.)
Thanks for any help you can provide.
Mike
