woodd
Aug 31, 2015Aspirant
FVS336G How do I change the certificate presented from 192.168.1.1 (Default admin)
I have the FVS336G installed to load balance between two internet providers (small office) The admin page is SSL secured with a self signed NetGear CA certificate - After I add this certificate into...
- Sep 03, 2015
Hi woodd,
The FVS336Gv1 does not have a console port whereas both the FVS336Gv2 and FVS336Gv3 does have a console port. However, there is still no option to update the admin certificate nor swap out the certificate file via a console connection.
As per the CLI reference manual, it says on page 6: "You cannot generate and upload a certificate through the CLI..." You may access the CLI reference manual here.
DaneA
Netgear Community Team
