Bridgford
Jul 17, 2018Aspirant
netgear srx5308 internet speed slow
My netgear srx 5308 only gives roughly 37mb internet speed even though there is a 200mb Virgin line.
Any ideas
DaneA
Jul 19, 2018NETGEAR Employee Retired
Thanks for the feedback. If you will not set the Hitron Virgin router to full bridge mode, you will have a Double NAT scenario in which this might be the reason why you are not able to get the internet speed you have subscribed through the SRX5308.
For more information about Double NAT, kindly access the articles below:
How to fix issues with Double NAT
DaneA
NETGEAR Community Team
fordem
Aug 05, 2018Mentor
Whilst "doubleNAT" is not optimal, the fact that he can swap out the SRX5308 for a Draytek router and get an immediate and significant increase in throughput indicates that doubleNAT is NOT the cause of the slow down.
- BridgfordAug 06, 2018Aspirant
Thanks for information.
Any other ideas on how to improve speed through netgear srx5308.
- DaneAAug 06, 2018NETGEAR Employee Retired
Kindly try this. On the web-GUI of the SRX5308, go to Security > Firewall > Attack Checks then uncheck the boxes that says "Block TCP flood" and "Block UDP flood." Then, observe if the same problem will occur. Refer to the image below:
DaneA
