mhndsh
Jun 12, 2018Aspirant
SRX5308 DHCP - no free leases
Hi
I have the latest firmware..4.3.5-3
i don't have 190 clients... IPs aren't released..
"er:no free release"
old posts are closed... i didn't try to do factory reset as i have a lot se...
JohnC_V
Jun 13, 2018NETGEAR Employee Retired
Hi mhndsh,
Please try to reboot the firewall and check the DHCP range that you set on your LAN network so that we may know what seems to be causing that issue. Do you have a wireless network?
mhndsh
Jun 23, 2018Aspirant
Yes i have wireless APs in the network... But access is limited...
The problem is that i am running out of IPs ... It says 80 leases are in llst... but i don't have that number if devices... Although i reduced the time to 3 hours... Same problem.
My ip range is from 10 to 180... It's 4 times what i need.
- Feb 25, 2019Anonymous
