sno's avatar
sno
Guide
Dec 23, 2020
XR500 DHCP Lease renewal causes connection drop
Hello, my lease renews every 24 hours, at which time I lose connection for about 30 seconds even though my ip never changes.  Is there a resolution for this issue?  My other Nighthawk R7000 router doesn't have this problem, lease renews without any connection loss.
Firmware versions I have tried:
XR500-V2.3.2.40.img
XR500-V2.3.2.56.img
XR500-V2.3.2.104-DumaOS3.0-Beta.img
Currently running: 2.3.2.40
Setting a static ip is not an option.
Thanks,
Jordan
  • Reporting back as I said I would, downgrading to firmware version 2.3.2.22 fixed my DHCP lease renewal connection drop issue for anyone that's having the same issue I recommend trying this.
    Cheers
    • sno's avatar
      sno
      Guide
      The connection drop problem is with the WAN, not the LAN.  The drop happens when the dhcp lease renews with my ISP.  I still have connections with my NAS via LAN when this happens so it's a WAN issue.
      My ISP doesn't allow me to set a static ip on the WAN without paying for a business line.
      Plus, setting a static IP isn't a fix, It's a workaround.  I shouldn't have to do that.  Dropping the connection everytime the WAN lease is renewed is ludicrous.
      Thanks for the link to that thread, I'll try to provide some logs.  I've searched the forums and see threads going back two years for this problem.  They are just now trying to address this major issue?  /rolls eyes
      Jordan
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        If you're not using a pure modem but it is a modem/router then on the interface for that you can give the XR a static IP which would resolve the issue and you don't need to pay anything. I've been pushing for the issue to be resolved so I'm hopeful if they get some useful information they can get it sorted sooner.
