cisberg
Jul 27, 2015Aspirant
Virtual Passage Installation error - Windows 7 and Netgear FVS336Gv2 VPN Firewall
 I have a Netgear FVS336Gv2 VPN Firewall with the firmware 4.3.3-5 installed but I can't get my Windows 7 Professional machines to connect properly.  The Windows 7 machines are 64-bit and they can log...
- Jul 27, 2015
I still can't get into the Community site to view the link you sent, but I was able to access the PDF you made available through the app.box. I followed those instructions and now I am able to get the Virtual Passage installation to work. Thank you for the help!
DaneA
Jul 27, 2015NETGEAR Employee Retired
Hi cisberg,
Just want to share this forum thread below about how to run SSLVPN on Windows 7 64-bit with IE 11 and it might help you as your reference guide as well:
DaneA
Netgear Community Team
cisberg
I tried clicking on the link but it says I don't have sufficient priviledges to access the information.
- DaneAJul 27, 2015NETGEAR Employee Retired
Hi cisberg,
After clicking the link and its asking you to enter login credentials, kindly enter your e-mail and password that you use to sign in here in the newly launch Netgear Community so that you could access the link I have provided on my previous response.
DaneA
- cisbergJul 27, 2015Aspirant
I tried again (closing out Chrome completely) and after entering my credentials I got the same "Access Denied" message.
Also, I just tried lauching the connection using IE 11 64-bit (instead of the default 32-bit) and I don't get the error message any more about adding the site to the Trusted Sites. However, the Virtual Passage installation still fails after I click on the VPN tunnel link.
