cisberg
Jul 27, 2015Aspirant
Virtual Passage Installation error - Windows 7 and Netgear FVS336Gv2 VPN Firewall
 I have a Netgear FVS336Gv2 VPN Firewall with the firmware 4.3.3-5 installed but I can't get my Windows 7 Professional machines to connect properly.  The Windows 7 machines are 64-bit and they can log...
- Jul 27, 2015
I still can't get into the Community site to view the link you sent, but I was able to access the PDF you made available through the app.box. I followed those instructions and now I am able to get the Virtual Passage installation to work. Thank you for the help!
cisberg
I installed the two items you mentioned and even after rebooting the Virtual Passage installation still fails. I double-check to make sure the site was in the Trusted Site and I verified that all ActiveX controls were set to either "Enable" or "Prompt". Is there anything else I can try? I don't understand how the firmware states it works for up to Windows 8.1 but I can't get the Windows 7 Professional computers to connect.
cisberg
