mpruss
Nov 10, 2015Aspirant
VPN client to UTM 50 strange address problems
I have a strange problem with the VPN client address that came up recently. We have a UTM 50 with the newest Firmware 3.6.2.1 There is a VPN set up for our customers to connect to servers in the...
- Nov 11, 2015
I solved the issue.
The client has an option named "Mode Config" in the extended Phase 1 configuration.
When I set this option the client receives an IP address from the VPN address pool and the route to the DMZ network is set correctly.
The strange thing is, that it worked without this option in Windows 7 for years.
mpruss
Nov 11, 2015Aspirant
I solved the issue.
