morrisonkena
Mar 20, 2017Aspirant
VPN MacOS client setup
Working to setup up a IPv4 Client-to-Gateway VPN tunnel for MacOS clients configuring the MacOS native VPN client (Network Settings, VPN Interface, Cisco IPSec type). It appears I have been successfu...
- May 21, 2017
I apologize for this is the only time I got back on this. Is your network setup as well as the settings on your FVS336Gv3 and MAC OS X Sierra the same as indicated on the article below?
Mac OS X VPN Client install with ProSAFE VPN Firewall/Router
DaneA
NETGEAR Community Team
DaneA
Apr 18, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to try the suggestions?
DaneA
morrisonkena
May 10, 2017Aspirant
Hi DanaA,
I am back from my travels out-of-town, cleared my backlog of tasks and am now fully focused on solving this VPN connectivity issue.
Know that I am not at all skilled in setup of VPN's. My current setup has an IKE Policy using a Mode Config, but has no VPN Policy set up. Perhaps I don't need an IKE Policy at all, and just a VPN Policy??
I am absolutely a believer in "reading the manual" before asking for help, so please do direct me to any background I can read before I ask for your generous help.
I confirrm the local IP address of my MacBook VPN client is different from the LAN subnet the firewall sits on. It should also be so, but I will have different DHCP assiged IP addresses as I move around to different host networks.
