ThHofer
Aug 19, 2017Aspirant
FirmwareUpdate with MacOS
Hi, I want to make a Firmware-Update;
but I don't have a Windows-Computer, just only MacOs.
Is it - hand how - is it possible to make a Update?
BR
Thomas
The manual that TheEther linked to seems to be explains this, but maybe it is a little unlcear from those instructions in the manual.
1. Download the firmware file first from support.netgear.com
2. Navigate to: "Maintenance" --> "Download" --> and select "HTTP" button.
3. A "Browse" button should appear where you can browse to the file you just downloaded on your computer and select it.
- HopchenProdigy
Hi,
What type of switch do you have?
You can upgrade the firmware via TFTP as well as by browser. Consult the manual.
- ThHoferAspirant
I read the instructions,
but I don't know, what the adresses of TFTP or HTTP, Filename, ... is...
- Are you able to log into the switch with a browser? If you've never logged in, then the default address is 192.168.0.239. You may need to change the IP address on your Mac to a suitable one in order to log in. The manual also describes how to do this.
Here is a different manual but it should be similar:
http://www.downloads.netgear.com/files/GDC/GS716TV2/GS716T_GS724T-SWA-October2012.pdf
