ThHofer
Aug 19, 2017Aspirant
FirmwareUpdate with MacOS
Hi, I want to make a Firmware-Update; but I don't have a Windows-Computer, just only MacOs. Is it - hand how - is it possible to make a Update? BR Thomas
- Aug 19, 2017
The manual that TheEther linked to seems to be explains this, but maybe it is a little unlcear from those instructions in the manual.
1. Download the firmware file first from support.netgear.com
2. Navigate to: "Maintenance" --> "Download" --> and select "HTTP" button.
3. A "Browse" button should appear where you can browse to the file you just downloaded on your computer and select it.
Hopchen
Aug 19, 2017Prodigy
Hi,
What type of switch do you have?
