ThHofer
Aug 19, 2017Aspirant
FirmwareUpdate with MacOS
Hi, I want to make a Firmware-Update; but I don't have a Windows-Computer, just only MacOs. Is it - hand how - is it possible to make a Update? BR Thomas
- Aug 19, 2017
The manual that TheEther linked to seems to be explains this, but maybe it is a little unlcear from those instructions in the manual.
1. Download the firmware file first from support.netgear.com
2. Navigate to: "Maintenance" --> "Download" --> and select "HTTP" button.
3. A "Browse" button should appear where you can browse to the file you just downloaded on your computer and select it.
TheEther
Aug 19, 2017Guru
You can upgrade the firmware via TFTP as well as by browser. Consult the manual.
ThHofer
I read the instructions,
but I don't know, what the adresses of TFTP or HTTP, Filename, ... is...
- TheEtherAug 19, 2017GuruAre you able to log into the switch with a browser? If you've never logged in, then the default address is 192.168.0.239. You may need to change the IP address on your Mac to a suitable one in order to log in. The manual also describes how to do this.
Here is a different manual but it should be similar:
http://www.downloads.netgear.com/files/GDC/GS716TV2/GS716T_GS724T-SWA-October2012.pdf - HopchenAug 19, 2017Prodigy
