ThHofer
Aug 19, 2017Aspirant
FirmwareUpdate with MacOS
Hi, I want to make a Firmware-Update; but I don't have a Windows-Computer, just only MacOs. Is it - hand how - is it possible to make a Update? BR Thomas
- Aug 19, 2017
The manual that TheEther linked to seems to be explains this, but maybe it is a little unlcear from those instructions in the manual.
1. Download the firmware file first from support.netgear.com
2. Navigate to: "Maintenance" --> "Download" --> and select "HTTP" button.
3. A "Browse" button should appear where you can browse to the file you just downloaded on your computer and select it.
ThHofer
I read the instructions,
but I don't know, what the adresses of TFTP or HTTP, Filename, ... is...
Hopchen
Aug 19, 2017Prodigy
