genesearch
Feb 16, 2016Aspirant
VPN use Mode Config Record fails
The FVS336G is the gateway and the LAN uses 192.168.1.x IP range. I can create the IPSEC VPN, using VPN Policy as per the instruction manual, and it works great, and so easy to configure. All my ...
genesearch
The complete log from the router.
Wed Feb 17 10:22:49 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: 192.168.169.1 IP address has been released by remote peer. Wed Feb 17 10:22:49 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: ISAKMP-SA deleted for 59.100.xx.xxx[500]-1.132.9.76[500] with spi:414c513b9c0a8545:f63016e5a78baa48 Wed Feb 17 10:22:48 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Purged ISAKMP-SA with proto_id=ISAKMP and spi=414c513b9c0a8545:f63016e5a78baa48. Wed Feb 17 10:22:41 2016 (GMT +1000): [FVS336GV3] [IKE] ERROR: Failed to get IPsec SA configuration for: 192.168.169.1/24<->192.168.43.178/32 from vpnclient.private Wed Feb 17 10:22:41 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Responding to new phase 2 negotiation: 59.100.xx.xxx[0]<=>1.132.9.76[0] Wed Feb 17 10:22:36 2016 (GMT +1000): [FVS336GV3] [IKE] ERROR: Failed to get IPsec SA configuration for: 192.168.169.1/24<->192.168.43.178/32 from vpnclient.private Wed Feb 17 10:22:36 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Responding to new phase 2 negotiation: 59.100.xx.xxx[0]<=>1.132.9.76[0] Wed Feb 17 10:22:31 2016 (GMT +1000): [FVS336GV3] [IKE] ERROR: Failed to get IPsec SA configuration for: 192.168.169.1/24<->192.168.43.178/32 from vpnclient.private Wed Feb 17 10:22:31 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Responding to new phase 2 negotiation: 59.100.xx.xxx[0]<=>1.132.9.76[0] Wed Feb 17 10:22:30 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Sending Informational Exchange: notify payload[INITIAL-CONTACT] Wed Feb 17 10:22:30 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: ISAKMP-SA established for 59.100.xx.xxx[500]-1.132.9.76[500] with spi:414c513b9c0a8545:f63016e5a78baa48 Wed Feb 17 10:22:30 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: 192.168.169.1 IP address is assigned to remote peer 1.132.9.76[500] Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Received Vendor ID: DPD Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Received unknown Vendor ID Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Beginning Aggressive mode. Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Received request for new phase 1 negotiation: 59.100.xx.xxx[500]<=>1.132.9.76[500] Wed Feb 17 10:22:29 2016 (GMT +1000): [FVS336GV3] [IKE] INFO: Remote configuration for identifier "vpnclient.private" found
adit
Feb 16, 2016Mentor
If I remember correctly Mode Config did not work with IPSecuritas.
LAN1 192.168.1.0 to LAN2 192.168.1.0 will never work.
If you are concerned about common LAN subnets having an issue with yours then you will need to change it.
These are the one you should not use if you have VPN Client users attaching to your network.
LAN Subnets NOT to Use
192.168.0.0
192.168.1.0
192.168.5.0
192.168.10.0
192.168.50.0
192.168.100.0
10.0.0.0
10.0.10.0
172.16.0.0
172.31.0.0
