danny_lang1
Sep 02, 2015Follower
Why does the fvs318 firewall only pass 5gbps signal from a 30gbps signal line?
OK, I have setup a connection through a local cable ISP @30gbps and bypassing the built in wireless function in an Arris 860 modem. Unfortunately the ISP is in control of the Arris settings with that ...
JohnRo
Sep 07, 2015NETGEAR Employee Retired
Hello GuillermoPiquer,
That's fairly low for an FVS336Gv2, do you have any firewall rules on the router? I have checked your support ticket and it is currently handled by engineering/Level 3. We'll have to wait for an update and see what is going on with your device.
I'll keep an eye on this post for updates.
Thanks,
GuillermoPiquer
Sep 08, 2015Aspirant
Thanks. It's probably a firmware / ROM confict, I think, because we begun with a firmware 3.x (don't remember exactly) and with optimal trhoughtput. Then, after a penetration test detected we have to update firmware to latest version for major security. None of the firmware updates or downgrades have solved the speed issue yet. We have VoIP, some VPN tunnels with other office cities, about 40 outbound rules... And everything is bad, nobody is happy now. We get the 1 year suppoort service and begin friday with call support (before via email support same issue). The support team are very frindly, yes, but not solving anything and the stage is maddening. Bosses are asking for another device not negear.
- JohnRoSep 08, 2015NETGEAR Employee Retired
I'll follow up with support to have your case in priority, as of now we'll have to wait on the diagnosis.
If you have more questions, please feel free to ask.
Thanks,
