GrayHairCoder's avatar
Oct 03, 2020
Recommend replacement for FVS318
Have a  FVS318 with firmware FVS318v3_v3.0_28 I am having issues with it staying conected to  a Century Link T1 Adtran router. Having to power cycle several times a day to re establish connection. So probably best to replace would be nice to upload exported cnfg file to another Netgear VPN Firewall router as I have about 60 settings that  I would have to enter.
But I am sure no curretn products are compatable for that to be an a option.
Anyway wtihn the current VPN Firewall Routers what would be a suggested replacmenti .have about 6-8 PCs RDPing to server so LAN  to WAN Throughtput is an issue
Not deidacted to Netgear but up until a month ago happy with everthing expect droping conection.
 LAN  to WAN Throughtput has always been marginal.
Thanks
Ralph
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    GrayHairCoder,
    Welcome to the community! :)
    The FVS318v3 is already EoL (End-of-Life) many years ago.  If you plan to upload its config to another NETGEAR VPN Firewall, you should upload it to another FVS318v3.  It is because the NETGEAR VPN Firewall models have different hardware platforms and different firmware versions.  For example, you cannot upload the config file of the FVS318v3 to the FVS336Gv3 (also EoL) because doing so will just brick the device.
    In replacement of the FVS318v3, I suggest you the BR200.  Be reminded that you cannot upload the config file of the FVS318v3 to the BR200 as well.  To know more about the specifications of the BR200, kindly check its data sheet here.
    DaneA
    NETGEAR Community Team
    • Re: Recommend replacement for FVS318
      Do I have to subscribe/or use the insight software to configure or maintain the router.
      Dont want to pay a subscription fee. Has this router been released I notice on Amazon the ships dates are weeks out?
      • DaneA's avatar
        DaneA
        GrayHairCoder,
        Yes, you will need to subscribe with NETGEAR Insight.  For more information about the NETGEAR Insight Subscription Plans, kindly access the links below:
        What Insight subscription plans are available?
        You can still managed the BR200 through its web-GUI without paying for an Insight Subscription.  The BR200 has been newly released more than a month ago.
        DaneA
ProSupport for Business
