Jodyjay
Jan 09, 2024Aspirant
Comcast Router Recommendations
I currently have a Motorola MB8600 modem, and an Orbi mesh router system (RBR750 router and two RBS750 satellites). The MB8600 is a DOCSIS 3.1 modem with a 1 gbps port. I believe my internet plan with Comcast is 400 mbps. Comcast send an email saying that I can increase the speed of my download 5-10x by upgrading my modem. 2 of the modems they recommend are the Netgear CM3000 and CBR750. My understanding is that the CBR750 is a combo modem and router, so that would not fit my needs. I have 2 questions about the CM3000:
1. Would it really increase my internet speeds over the MB8600?
2. If the CM3000 will increase my speeds, how do I find it. I have looked on the internet and I do not see it anywhere. The closest I see is a C3000.
Thank you.
- CrimpOnGuru - Experienced UserComcast is complicating your life for no purpose unless the maximum speed Comcast will support on this DOCSIS 3.1 modem is less than it is capable of. DOCSIS 3.1 supports up to 1GB/sec. The Orbi RBR750 WAN port is 1GB/sec. They match. Increasing the modem to greater than 1GB will be a waste of money because the modem will connect to the router at 1GB/sec. Increasing 400Mbit by 5-10 times is nonsense. The marketing department needs to be flogged. - CrimpOnGuru - Experienced UserOh, my. Folks on the internet have quite a bit to say about Xfinity marketing: - JodyjayAspirantThe MB8600 is still on Comcast's list of compatible modems. https://www.xfinity.com/support/devices/#auth
 Jodyjay wrote:
 I currently have a Motorola MB8600 modem, and an Orbi mesh router system (RBR750 router and two RBS750 satellites). The MB8600 is a DOCSIS 3.1 modem with a 1 gbps port. I believe my internet plan with Comcast is 400 mbps. Comcast send an email saying that I can increase the speed of my download 5-10x by upgrading my modem. 2 of the modems they recommend are the Netgear CM3000 and CBR750. My understanding is that the CBR750 is a combo modem and router, so that would not fit my needs. I have 2 questions about the CM3000: The CBR supports up to 1Gb ISP Speeds. 1. Would it really increase my internet speeds over the MB8600? Since the MB8600 only has 1Gb ports, then your max ISP speed will max out at this rate. If the ISP has this package which I don't believe so anymore as they did a split and now only support 800Mpbs and 1.2Gb. So 800Mbps would be something the current modem can handle. 2. If the CM3000 will increase my speeds, how do I find it. I have looked on the internet and I do not see it anywhere. The closest I see is a CM3000. Due to the CM 2000 and 3000 series, they have multi gig WAN ports that support connections higher than 1Gb so if the ISP supports 1.2Gb speeds, then these model modems would be able to handle it. CM3000 has not been released from NG. I presume sometime this year maybe this will come about. The CM2000 and CM2050v are released and supported by the ISP.
