MattMS
Apr 27, 2017Aspirant
Remote Client Full Tunnel VPN with SRX5308 and Shrew Soft - Some Websites Don't Load
Hi everyone, I've really been scratching my head on this one. Any help would be greatly appreciated. Remote users need to access remote servers through the office, which is whitelisted for ac...
- Apr 27, 2017
Dropping the computer's MTU down to 1380 resolved this. I ended up going back up to about 1400. Might be able to go a little higher, but the sites I needed to load were fine at 1400.
https://support.zen.co.uk/kb/Knowledgebase/Changing-the-MTU-size-in-Windows-Vista-7-or-8
MattMS
- DaneAMay 01, 2017NETGEAR Employee Retired
Hi MattMS,
Thanks for sharing the solution you did to resolve the problem. :)
I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
