jxdomb's avatar
jxdomb
Remote DNS for IPSec Tunnel Not Correct
I can establish a tunnel using the full VPN client to the FVS318N.  Routing into the remote private LAN works as expected.  However, DNS does not resolve to any of the names in the private LAN.  How can I adjust the IPSec policy and/or VPN client settings to get the private LAN's DNS server working?  Thanks!
  • Hi jxdomb,
    Welcome to the community! :)
    I am not sure if this will help.  However, let me share this forum link I found online.
    DaneA
    NETGEAR Community Team
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hi jxdomb,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Thanks,
    • jxdomb's avatar
      jxdomb
      The forum link did help me to understand that I needed to manually configure the remote subnet and DNS parameters in the VPN client, or to use a mode config record to have that information be provided by the router during negotiation.
      Thank you!
      • DaneA's avatar
        DaneA
        Hi jxdomb,
        I'm glad that the forum link I found online has helped you. :)
        Feel free to post your future concerns here in the community.
        Cheers,
        DaneA
  • DaneA's avatar
    DaneA
    Hi jxdomb,
    DaneA
ProSupport for Business
