ajinc
Feb 21, 2017Aspirant
Replaced NETGEAR FVS336G with NETGEAR SRX5308 how i can't access login.salesforce.com
Hello All, I had an FVS336v2 connected to a verizon dsl internet modem all worked fine for a number of years and lately we had been experiencing lan to internet connectivity and vpn to remote deskt...
- Feb 27, 2017
Hello All,
Thanks for the suggestions but my problem acctually was a pc on the network that had a bad nic in it and it was throwing so much chatter that it was very difficult to access web sites and for some reason it was preticularly hard to access login.salesforce.com
Once I removed the offending pc from the lan everything settled down and salesforce was accessible.
Again thanks for all suggestions that were offered they were greatly appreciated.
DaneA
Feb 26, 2017NETGEAR Employee Retired
Just following-up on this. We'd greatly appreciate your feedback.
DaneA
NETGEAR Community Team
- ajincFeb 27, 2017Aspirant
Hello All,
- DaneAFeb 27, 2017NETGEAR Employee Retired
Thanks for the feedback. I'm glad that you were able to isolate the problem and you're now able to access the salesforce. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
