chiragk11
Nov 23, 2016Aspirant
Restrict User to VLAN after VPN - Not working
Hello, On SRX5308 I have created a IPSec VPN connection using Mode Config and IKE policy. I am able to VPN in. However, I can access all Subnets - even though I have specified the Subnet as 10.5...
chiragk11
Never mind the last post #2. It seemed to work when I first connected, but after a minute, I was able to access entire network - so I back to square 1.
DaneA
Dec 05, 2016NETGEAR Employee Retired
Hi chiragk11,
Just to add, to possibly set the VPN to access only a specific VLAN other than the default VLAN, the setting for this to work is in the VPN Policy under Traffic Selection. By default, when creating the policy using the VPN wizard, it will use the IP address of the default VLAN. However, if you change this to the network address of the desired VLAN, it will allow access to that VLAN through the VPN. Inter VLAN routing must be turned off in the VLAN settings if the desired effect is to not be able to access other VLAN’s.
On the figure below, from the working policy; note that 192.168.245.0 is the network address of the secondary VLAN and not the LAN IP address of the default VLAN. Also note, Mode Config is not being used. Just use the VPN wizard on both the SRX5308 on each side.
DaneA
NETGEAR Community Team
