Jim_Young
Apr 15, 2016Initiate
Route printing across VLANS with SRX5308
I have an SRX5308 with three VLANS setup: 192.168.1.1 192.168.2.1 192.168.3.1 All are subnet mask 255.255.255.0. Each has it's own DHCP range. Each as a dedicated LAN port on the firewall. Curren...
KBXR
Apr 16, 2016Aspirant
I have a similar issue using an M4100 switch.
You say "... create a new VLAN on the switch making the printer a part of the three VLANs." Exactly HOW you would go about doing that?
I'm going to guess:
- three vlans already exist
- ports 1-6 are vlan 101, IP network 192.168.10.0
- ports 7-12 are vlan 102, IP network 192.168.20.0
- ports 13-18 are vlan 103, IP network 192.168.30.0
- create a vlan of ports 19-24 IP network 192.168.40.0 and hang the printer off that vlan
- Make ports 1-18 part of vlan 104
- enable IP routing.
Am I close?
KBXR
Apr 17, 2016Aspirant
lol -- I used the very phrase I didn't understand when you said it. Human beings -- wow.
OK, so what I mean is that once the vlans 101, 102, 103, are setup
- Make ports 1-18 part of vlan 104 by tagging all of the ports with a U but only ports 19-24 have a PVID of 104
lol - I'm still not sure that I'm being as clear as I need to be.
