Jim_Young
Apr 15, 2016Initiate
Route printing across VLANS with SRX5308
I have an SRX5308 with three VLANS setup: 192.168.1.1 192.168.2.1 192.168.3.1 All are subnet mask 255.255.255.0. Each has it's own DHCP range. Each as a dedicated LAN port on the firewall. Curren...
Jim_Young
Apr 25, 2016Initiate
Problem solved, with some insight from the folks who posted. Thank you all.
I created a separate VLAN just for the printer and made it a member of all of the other VLAN ports. In turn, I gave each of the other VLANS membership on the default port for the printer's VLAN. Then I used unmanaged switches on the ports that needed them.
Below is the full setup. This is for a small public library -- the goal was to keep library patrons out of the staff side of the network. I'm also using OpenDNS for filtering and bandwidth profiles so that one kid on a patron computer can torrent a movie at full speed and kill the entire network.
Thank you again for all the help.
VLAN1 – printers:
- Name: Default
- Port membership: 1,2,3,4
- IP: 192.168.10.1
- SN: 255.255.255.0
- DHCP range: 192.168.10.100 to 192.168.10.199
- Primary DNS: 208.67.222.222
- Secondary DNS: 208.67.220.220
- DNS Proxy: off
- Inter VLAN routing: on
VLAN102 – Staff:
- Name: StaffVLAN
- IP: 192.168.20.1
- SN: 255.255.255.0
- DHCP range: 192.168.20.100 to 192.168.20.199
- Primary DNS: 8.8.8.8
- Secondary DNS: 8.8.4.4
- DNS Proxy: off
VLAN103 – Patrons:
- Name: PatronVLAN
- Port membership: 1,3
- IP: 192.168.30.1
- SN: 255.255.255.0
- DHCP range: 192.168.30.100 to 192.168.30.199
- DNS Proxy: off
VLAN104 – Wi-Fi:
- Name: WiFiVLAN
- Port membership: 1,2,4
- IP: 192.168.40.1
- SN: 255.255.255.0
- DHCP range: 192.168.40.100 to 192.168.40.199
- DNS Proxy: off
LAN Default Ports:
- Port 1 – default (printer)
- Port 2 – VLAN102 (Staff)
- Port 3 – VLAN103 (Patrons)
- Port 4 – VLAN104 (WiFi)
- JohnRoApr 25, 2016NETGEAR Employee Retired
Hello Jim_Young,
We are glad to know that you have it working! If ever one of the posts on this thread helped fix the issue please click on "Accept as Solution", this will help other community members if in case they encounter the same setup.
Thanks,
