GaACETech
Sep 29, 2016Guide
Router - Dual WAN
A company I support has awful Internet access due to the cable company having issues. There is another cable provider available. The question: which router can have two different WAN ports c...
- Sep 30, 2016
I'd go for a FVS336Gv3 and buy a dedicated AP. You can use the FVS318N kind of like an AP by doing the following;
*Factory default the FVS318N
*Change management IP since the default IP of the FVS318N is the same as the FVS336Gv3
*Turn off the FVS318N DHCP server
*Create a wireless SSID
*Plug the FVS318N in to the FVS336Gv3 using a LAN port (so LAN-LAN), do not plug anything in to the WAN port
This is assuming that you don't use multiple VLANs in which case you may need some additional configuration. But like I said a dedicated AP is probably a good idea anyways.
Attaching possible topology with the FVS318N:
dmacleo
Sep 30, 2016Guide
fvs336gv3 should work, I only hvae one single provider here so cannot test specifically but the 336 supposed to do auto fallover between wan ports.
JohnRo
Sep 30, 2016NETGEAR Employee Retired
Hello GaACETech,
dmacleo is correct, along with the auto-failover feature the FVS336Gv3 also comes with load balancing. Both WAN ports can be used as a primary or failover port. Please click here for complete details.
Let us know if you have more questions.
Thanks,
- GaACETechSep 30, 2016Guide
Is there a WiFi version of the FVS336v3? or just a Access Point? we have a single WAN port Netgear now. i think that can be made a AP.
- JohnRoSep 30, 2016NETGEAR Employee Retired
Hi GaACETech,
Unfortunately, we do not have a wireless firewall as of the moment. Yes, we can have it configured as an AP. What's the model number btw?
Thanks,
