GaACETech
Sep 29, 2016Guide
Router - Dual WAN
A company I support has awful Internet access due to the cable company having issues. There is another cable provider available. The question: which router can have two different WAN ports c...
- Sep 30, 2016
I'd go for a FVS336Gv3 and buy a dedicated AP. You can use the FVS318N kind of like an AP by doing the following;
*Factory default the FVS318N
*Change management IP since the default IP of the FVS318N is the same as the FVS336Gv3
*Turn off the FVS318N DHCP server
*Create a wireless SSID
*Plug the FVS318N in to the FVS336Gv3 using a LAN port (so LAN-LAN), do not plug anything in to the WAN port
This is assuming that you don't use multiple VLANs in which case you may need some additional configuration. But like I said a dedicated AP is probably a good idea anyways.
Attaching possible topology with the FVS318N:
GaACETech
Sep 30, 2016Guide
The current router is a NETGEAR ProSAFE FVS318N 8-Port Wireless-N VPN Firewall with SSL and IPSec VPN (FVS318N-100NAS)
Danthem
Sep 30, 2016NETGEAR Employee Retired
- JohnRoOct 06, 2016NETGEAR Employee Retired
Hi GaACETech,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
