WestNordic
Jun 12, 2015Aspirant
SBS 2008 Firewall configuration in FVS338?
Hi, have got a FVS338 as router/firewall between WAN and LAN. On the LAN is a SBS 2008 server running Exchange and SharePoint. The server also handles DHCP and DNS (DHCP turned of in FVS338). With ...
fordem
Jun 15, 2015Mentor
Why are you using port translation? Create an inbound service to forward port 987 to the server on port 987.
I've attached a link to a list of the ports used by Outlook to communicate with Exchange, you'll need to figure out which ones are critical to your use and forward those, some, like 135, I would not suggest you forward - when I ran exchange I used OWA for external access.
https://support.prolateral.com/index.php?/Knowledgebase/Article/View/179
https://support.microsoft.com/en-us/kb/270836
