WestNordic
Jun 12, 2015Aspirant
SBS 2008 Firewall configuration in FVS338?
Hi, have got a FVS338 as router/firewall between WAN and LAN. On the LAN is a SBS 2008 server running Exchange and SharePoint. The server also handles DHCP and DNS (DHCP turned of in FVS338). With ...
WestNordic
Jun 17, 2015Aspirant
fordem wrote: Why are you using port translation? Create an inbound service to forward port 987 to the server on port 987.
I've attached a link to a list of the ports used by Outlook to communicate with Exchange, you'll need to figure out which ones are critical to your use and forward those, some, like 135, I would not suggest you forward - when I ran exchange I used OWA for external access.
https://support.prolateral.com/index.php?/Knowledgebase/Article/View/179
https://support.microsoft.com/en-us/kb/270836
Thanks, knew I was missing something.
Inbound service for port 987 was exactly what I meant to-do but got it mixed up with port translation.
Was looking for rules and not services, terminology mix-up.
Now SharePoint intranet (port 987) works from intranet.
But Outlook client still will not work.
OWA does work but we want the full Outlook Windows client as we regularly work out of office.
That list of ports looks to be much more than I would like to open up in the firewall.
Had it working before but unfortunately lost the configuration and don't have it documented :mad:
