smpjmp
Dec 13, 2016Aspirant
Security camera viewing on local network and remote viewing
This might be the wrong equipment for the application, but this is what was purchased and we would like to get it working. Here is the configuration: Cable modem is attached to WAN1 and the FVS3...
- Dec 15, 2016
Hi and thanks for the response
I fixed it last night by adding the devices as services in the services tab and rules in the LAN to wan rule tab to allow redirection to the IP addresses in question. Not something i have had to do with other routers.
Thanks again!
Steve
DaneA
Dec 15, 2016NETGEAR Employee Retired
Hi smpjmp,
Welcome to the community! :)
As far as I know, the FVS336Gv3 does not support NAT Loopback. Kindly answer the questions below:
a. What is the specific model of the Nighthawk wireless router set as Access Point mode?
b. What is the model of the 24-port NETGEAR Gigabit switch? Are there any other VLANs configured to it?
c. Is the cable modem a combination of modem-router or just a modem-only device?
d. What is the brand and model of the surveillance camera?
e. Are there any ports needed to be configured for port forwarding for the surveillance camera?
DaneA
NETGEAR Community Team
- smpjmpDec 15, 2016Aspirant
Thanks again!
Steve
- DaneADec 15, 2016NETGEAR Employee Retired
Hi smpjmp,
I am glad that you were able to resolve the problem. :) Thanks for sharing the fix you've done to resolve the problem here in the community
Feel free to post your future concerns here in the community.
Cheers,
DaneA
- SamirDDec 18, 2016Prodigy
Glad you solved the problem, but I would caution on using wireless for security cameras as any inexpensive wifi jammer can render your security system useless. Just a little fyi.
