rtr
Jan 19, 2017Tutor
Session closed with error when uploading CA certificate
Hello, I have a FVS318N, firmware version 4.3.4-2. I'm trying to upload a CA certificate in the VPN/Certificates, but this fails. The session is suddenly closed with simply the following messa...
train_wreck
Jan 19, 2017Luminary
dumb stuff, but is the time/date set on the FVS?
also, the CA cert has to be in .PEM (text-readable) format (it probably already is, if you can copy/pase the raw data from it into the forum here)
