thxbox1138
Mar 13, 2021Aspirant
Site to Site tunnel working (only ping)
I have 2 BR200 routers and 2 locations I set up site to site IPsec vpn Tunnel is green I can ping IP's from either site back and forth I cannot however map drives to my server from remote site ...
MrJoshW
Mar 15, 2021NETGEAR Employee Retired
Hello,
Are you able to ping the clients/servers in question? What firmware version is the BR200 on?
- thxbox1138Mar 15, 2021Aspirant
I am able to ping a machine from HQ to remote
I am able to ping a machine from remote to HQ
I am able to tracert from both locations and its 3 hops
HQ router
Remote router
machine
I just cant do anything else, my question is do I need to create any addtional traffic rules to allow the remote subnet machine to access the HQ network machine on the BC200 router or is that all taken care of once you create the IPSEC tunnel in the BC200's
meaning create the tunnel and done, no post rules or configuration?
I have no firewalls or anything in the way at this moment
- MrJoshWMar 16, 2021NETGEAR Employee Retired
Hello,
The issue is, on the BR200/500 we have disabled NATloopback due to performance. We do have a firmware that does address the NATloopback and will allow you to connect to the remote resources but please note that there will be a performance hit due to this. Please let me know if you wish to install the firmware for testing and I can send it to you through a private message.
- thxbox1138Mar 16, 2021Aspirant
I guess I have a couple questions
why would you limit a site to site tunnel since the very reason why people setup a site to site tunnel is to connect to the remote resources? and then why would the only way to to connect to the remote resources would be I would have to settle for crappy performance? why cant I have the option to connect to the remote resources and have great performance?
what is the difference between setting up a site to site VPN tunnel like I have and doing it though the insight manager with a VPN group are they the same I was going to keep insight premiere pro if this is the case
honestly if you say the only way to access remote resources from one site to the other is with crappy performance I might rethink your solution all together, who buys site to site tunnel solutions to be able to use just ping? this makes absutely no sense?
