thxbox1138
Mar 13, 2021Aspirant
Site to Site tunnel working (only ping)
I have 2 BR200 routers and 2 locations I set up site to site IPsec vpn Tunnel is green I can ping IP's from either site back and forth I cannot however map drives to my server from remote site ...
thxbox1138
Mar 18, 2021Aspirant
I would like to go the proxy insight way how can I get this all set up it sounds like this would be the better way to go and would help with the mapped drive issues, I also would be adding another router as well, we currently have insight premiere support and if we can do it this way we would plan on paying for this service going forward so I assume I can call support and get this all setup? I saw a option to give support access to the routers also
MrJoshW
Mar 19, 2021NETGEAR Employee Retired
As long as you have entitlements on the product for support, yes you can reach out to support to open a case. You can view the products entitlements under your my products section in MYNETGEAR.
- thxbox1138Mar 27, 2021Aspirant
Please send me the link for the 5.9 code for my BR200 I dont see it under downloads on main site
