Ridwan
Sep 14, 2016Tutor
SRX5308 - DHCP client list not working after upgrade to 4.3.4-1
LAN Groups page (Network Configurioton > LAN Settings > LAN Groups) doesn't display any list of devices after Firewall SRX5308 has the firmware version 4.3.4-1 applied to it. It would list all device...
- Sep 14, 2016
Hi Ridwan,
I believe that your concern is the same as your post on the forum thread here. Kindly answer the questions below:
a. Have you performed a factory reset after upgrading the firmware to v4.3.4-1 then reconfigure it from scratch?
b. Have you tried to select/click refresh after selecting the LAN Groups screen?
DaneA
NETGEAR Community Team
DaneA
Sep 14, 2016NETGEAR Employee Retired
Hi Ridwan,
DaneA
- RidwanSep 14, 2016Tutor
Hi DaneA,
Thank you very much for your reply. Your advice (b) about clicking the Refresh link from the top right did the trick. I can't believe that it was so bleeding obvious but in the previous firmware I never had to do that and hence I didn't even notice that or thought of using that Refresh link. Thanks heaps again, you made my day.
regards
Ridwan
- DaneASep 15, 2016NETGEAR Employee Retired
Hi Ridwan,
You're welcome! :) I'm glad the problem is now resolved.
Feel free to post your future concerns here in the community.
Cheers,
DaneA
