Ridwan
Sep 14, 2016Tutor
SRX5308 - DHCP client list not working after upgrade to 4.3.4-1
LAN Groups page (Network Configurioton > LAN Settings > LAN Groups) doesn't display any list of devices after Firewall SRX5308 has the firmware version 4.3.4-1 applied to it. It would list all device...
- Sep 14, 2016
Hi Ridwan,
I believe that your concern is the same as your post on the forum thread here. Kindly answer the questions below:
a. Have you performed a factory reset after upgrading the firmware to v4.3.4-1 then reconfigure it from scratch?
b. Have you tried to select/click refresh after selecting the LAN Groups screen?
DaneA
NETGEAR Community Team
DaneA
Sep 14, 2016NETGEAR Employee Retired
Hi Ridwan,
DaneA
Ridwan
Sep 14, 2016Tutor
Hi DaneA,
Thank you very much for your reply. Your advice (b) about clicking the Refresh link from the top right did the trick. I can't believe that it was so bleeding obvious but in the previous firmware I never had to do that and hence I didn't even notice that or thought of using that Refresh link. Thanks heaps again, you made my day.
regards
Ridwan
- DaneASep 15, 2016NETGEAR Employee Retired
Hi Ridwan,
You're welcome! :) I'm glad the problem is now resolved.
Feel free to post your future concerns here in the community.
Cheers,
DaneA
