kanfa
Jun 21, 2015Aspirant
SRX5308 - Multi-homing / Connecting subnets
Hi! I've reached the point where I've exhausted my primary DHCP scope (e.g. 10.10.10.x) and need to create a secondary scope (10.10.11.x). DHCP is handled by the server, and a superscope has been conf...
fordem
Jun 23, 2015Mentor
Definitely a bad choice of words, anyone who has the smarts to limit the DHCP pool in that manner has to have a pretty good idea of what they're up to - let me make a suggestion from a different angle - I'm not certain if you can do this with the SRX, but I can do it on the FVS318N, so I think the SRX should have the capability.
I'd like to think that you did not have 90 visitors all at the same time, so the problem would actually have been a shortage of available addresses, even though many of those allocated were not in use.
This not normally an issue unless you're in any environment where there is a rapidly changing client population - my suggestion is to shorten the lease duration, rather than adding more.
