tokey63
Feb 15, 2018Aspirant
SRX5308 - Static Route LAN to WAN Interface
Hi, I was wondering if it is possible to setup a firewall rule or static route to route ALL traffic from an IP address to use ONLY a specific WAN interface. In my case, I have a device I want to use...
DaneA
Mar 01, 2018NETGEAR Employee Retired
I just want to follow-up on this. We’d greatly appreciate your feedback.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
- tokey63Mar 01, 2018Aspirant
this is a bit confusing. My apologies. What i want is for ALL traffic (outbound and inbound) for say PC @ 10.16.1.133 to use WAN2 (secondary). If we are using load balance, sometimes is uses WAN1 and other times it uses WAN2. I want it to ALWAYS use WAN2 and only that device.
- DaneAMar 01, 2018NETGEAR Employee Retired
Thanks for the feedback.
If Load Balancing Mode is configured on the SRX5308, I suggest you to configure Protocol Binding wherein you can set the service, specify the WAN port (example: WAN2 port) and the source/destination IP address (example: 10.16.1.133). Kindly read pages 41-44 of the SRX5308 reference manual here about Load Balancing Mode and Protocol Binding.
DaneA
- DaneAMar 07, 2018NETGEAR Employee Retired
Just following-up on this. We’d greatly appreciate your feedback.
Regards,DaneA
