jrpsupport
Jan 15, 2014Tutor
SRX5308 - WAN2 not working
I have confirmed with the Data Centre that there is a green light on at both ends of the WAN Broadband connection, on WAN Port 2 on the SRX5308 AND at their Network Supply Port. WAN 1 is working pe...
jrpsupport
Jan 16, 2014Tutor
Thank you ADIT
I set up the Auto-rollover option as per attached screenshot.
Would that not work as well ?
My goal is to test that WAN2 works, before switching broadband cables in WAN1, eventually only needing to use WAN1 again.
