david78
Sep 17, 2014Aspirant
SRX5308 : Load balancing & DMZ problem
Hello, I have an easy setup : 2 dynamic IP address WAN1, WAN2 Load Balancing Round robin enabled. DMZ activated One Firewall rules WAN-> DMZ allow traffic port 80 to a DMZ machine. If Load b...
david78
Hello Fordem,
Thanks again for your reply,
To answer your question I had to create a rule to allow incoming traffic on port 80 to a specific machine running in the DMZ zone. This is a normal behaviour. If I do not apply this ; then no traffic is going to my web server.
Having said that; the configuration works perfectly under LAN and load balancing enabled. However with the DMZ interface enabled things goes wrong; If there is not other comment; I will report it to Netgears support team.
If you have any other suggestion; let me know.:):):)
David
David
