david78
Sep 17, 2014Aspirant
SRX5308 : Load balancing & DMZ problem
Hello, I have an easy setup : 2 dynamic IP address WAN1, WAN2 Load Balancing Round robin enabled. DMZ activated One Firewall rules WAN-> DMZ allow traffic port 80 to a DMZ machine. If Load b...
Baloba
Oct 08, 2015Aspirant
Hi.
Sorry for my bad english. Hope you understand what I mean :)
My setup is like Davids and im having the same problem.
I have a edge transport server in the dmz and have made a firewal rule WAN->DMZ on port 25 and selected wan destination ip adress to "WAN1"
We can say that my ip on wan1 is 10.0.0.1 and wan2 is 10.0.1.1
When I check my 25 port with open port check tool it sometimes is open and sometimes is closed.
If I check port 25 on 10.0.0.1 and 10.0.1.1 then I can see that port 25 is open sometimes on wan1 and sometimes on wan2 even if I selected wan1 in the firewal rule.
If i check other ports in the lan-wan firewall it always stays on wan1.
My problem is that I want port 25 to stay open on wan1 :)
My firmware version is 4.3.3-5
